It is currently Thu Jul 24, 2025 12:37 am
PostPosted: Thu Dec 29, 2005 6:54 am
I ran up to Tim's today to have him help me with a little sanding. I have to say that grizzly 18" wide belt sander is one of the nicest things I have ever seen.
It blows away drum sanders.
I have a so-so Performax 16/32 and thought I was going to upgrade to a larger drum sander.... Now I am going to save my pennies for one of these.... Wow.
Thanks again Tim.Brock Poling38715.6210532407
PostPosted: Thu Dec 29, 2005 6:58 am
Brock that looks a really nice machine, did I understand that you can programme a thickness and it takes care of it ? or have I got this wrong ?
PostPosted: Thu Dec 29, 2005 7:30 am
I know a local furniture builder who has the 24" duel belt thickness sander from Grizzly and he does not use the programable height adjustment option anymore as he did use it shortly after he purchased the machine and the bed just kept coming up till it sanded a small hollow in the belt. Well, he just doesn't trust the programable height adjustment anymore, just does it manually, motorized of course, just flicks the switch himself.
So, be warned.Rod True38715.6467476852
PostPosted: Thu Dec 29, 2005 7:39 am
Brock - I've been tellin that for many a month now! What a difference Ay !
PostPosted: Thu Dec 29, 2005 7:58 am
I'll give you $100 for that crappy Performax.
PostPosted: Thu Dec 29, 2005 9:09 am
First name: Josh
Last Name: French
City: Houston
I'll take all 3 of the sanders at $95 a piece!
Instagram: @jfrenchluthier
PostPosted: Thu Dec 29, 2005 9:18 am
Wasn't that the Monkees?
Seriously, it looks like an incredible machine, and I'm not the least suprised to hear it's that good. Unfortunately, money and space are lacking to acquire such a wonderful tool. Not to mention dust collection for something like that...
PostPosted: Thu Dec 29, 2005 9:51 am
I'd buy one today if I had the room!
We had a big 24" or larger one at Pantheon. Saves so much time.
PostPosted: Thu Dec 29, 2005 10:12 am
[QUOTE=RussellR] Brock that looks a really nice machine, did I understand that you can programme a thickness and it takes care of it ? or have I got this wrong ?[/QUOTE]
Yes, you just type in the decimal dimensions and just like magic... everything adjusts. Very slick.
PostPosted: Thu Dec 29, 2005 10:13 am
[QUOTE=Dave-SKG] Brock - I've been tellin that for many a month now! What a difference Ay ![/QUOTE]
It isn't that I didn't believe you... but all I have ever seen in action is a drum sander... sometimes very big, very nice drum sanders... but still a drum sander. I just figured it was "like" a bigger nicer drum sander...
WRONG!!!
This is an entirely different animal. Brock Poling38715.7602314815
PostPosted: Thu Dec 29, 2005 1:17 pm
The cool part is that as the wood is going through the sander I just type in the next dimension on the keypad and as soon as the wood exits the belt I hit the enter button and it auto indexes to the next cut dimension. It is so cool and FAST. I have been running a lot of oily [dark purple] EIR through it and not even a HINT of gunk building up on the belt.
Brock asked if I had much tweaking to do when I got the sander. This is the first power tool I have ever owned that came set up perfect out of the crate. We measured the wood of Brock's after we sanded it and it was within .002" on all four corners. This wood came right off the rubber conveyer belt and wasn't run on a platten. The wood I run on plattens comes out within .000" on all four corners which just amazes me.
The only draw back is I have to install new electrical service to the shop. I have to shut off most of my lights, fans, radio, etc... in order to start this beast up. It pulls 60 amps on start up and drops back to around 20 when it's runnning. If I take a .025" cut it will draw around 25 amps and a .035" cut will draw 30 amps.
tim...
PostPosted: Fri Dec 30, 2005 5:12 am
Ouch! Add the dust collector and compressor at the same time, and that is a big, big draw on any residential circuit. Did your utility bill take a big hit, too? Must have....
PostPosted: Fri Dec 30, 2005 5:54 am
Dang! What a machine! Wish ya lived closer Tim
PostPosted: Fri Dec 30, 2005 6:10 am
Hey Tim
I forgot to tell you that I'm on my way to your place with 100 sets to sand.
PostPosted: Fri Dec 30, 2005 6:28 am
Brock - yea it is...I was blown away too...some things you just have to see...
Tim - I realy feel bad that you had to re-wire in order to run this machine. I'll gladly take it off your hands for the cost of shipping ( which is a lot, I know.) I wouldn't want you to get used to that puppy and then let it rust in the corner for lack of amperage.
PostPosted: Fri Dec 30, 2005 7:35 am
Hey..once you have a wide belt experience you never go back to the old methods!
PostPosted: Fri Dec 30, 2005 8:12 am
[QUOTE=Don Williams] Wasn't that the Monkees?[/QUOTE]
No that was "I'm a believer".....A beliver is some sort of insect internal organ.
PostPosted: Fri Dec 30, 2005 10:34 am
[QUOTE=John How] [QUOTE=Don Williams] Wasn't that the Monkees?[/QUOTE]
No that was "I'm a believer".....A beliver is some sort of insect internal organ.[/QUOTE]
You funny!!!!!
PostPosted: Fri Dec 30, 2005 10:46 am
Is that anything like I'm a bepancreas?
